Thread: Good Unsharp Mask Settings
    8
    Default Good Unsharp Mask Settings
    For those with Photoshop, I learned some good Unsharp mask settings that can be generally applied to images to sharpen them up...
    Hmm why do they call it \"Unsharp Mask\" when it actually sharpens images????
    Anyway, Here are the settings:
    Amount: 50%
    Radius: 0.3
    Threshold: 0
    Depending on the image, you may need to apply this more than once and up to 3 times, but beware that it does exacerbate noise once you apply more than twice. It is also good as a general sharpener after you downsize images (which tends to soften them up a little).
    Anyway hope that helps. It doesnt work for all images but works better than that basic sharpening tool in Photoshop, in my opinion.
    278
    Default No Right Unsharp Mask Setting...
    What settings you use depends on the image and what you want to accomplish.
    For instance, there\'s a proceedure called \"Local Contrast Enhancement\" that uses some really strange settings:
    Amount — 20%
    Radius — 50
    Threshold — 0
    Check it out at:
    http://luminous-landscape.com/tutori...ancement.shtml
    Also do a search for \"Local Contrast Enhancement\" on Google.com.
    As for the background of the unsharp mask, it comes from a method in the traditional darkroom. To sharpen an image one would create a blurred (or unsharp) negative of the original, and then overlay the two images and create a final print from that.
    116
    Default Re:No Right Unsharp Mask Setting...
    Here\'s a link to another sharpening method that also can be used with success on some images:
    http://luminous-landscape.com/tutori...arpening.shtml
    What they say about sharpening can be undone since its done to a separate layer seems redundant knowledge. I always sharpen separate layer first and if happy merge or flatten the image.
    Ken
    E1 +SHLD-2, ZD14-54, ZD 50-200, EX-25, VLA-1, Fl-36, B+W Käseman Circ Pol, B+W UV MRC, B+W ND2, Cokin ND grad, Gitzo 2220, Ballhead 1276 and LowePro Dry Zone Rover, Sandisk and Transcend CF cards, PS CS3, Olympus Viewer, MacPro + Cinema display
    http://www.ephotozine.com/user.cfm?user=19806
    I agree with mikefellh, the settings you use will vary depending on the image you\'re working with and what you want to achieve. I recommend the book \"Photoshop CS2 for Digital Photographers\" by Scott Kelby. It provides lots of step-by-step instructions.
    As for why it\'s called the Unsharpen Mask, it refers to the underlying steps required to \"sharpen\" an image. If the Unsharpen Mask filter didn\'t exist and you had to sharpen an image manually, you would create a series of layers and use the Gaussian Blur filter (to \"blur\" is to \"unsharpen\") and possibly the Emboss filter on select channels and/or layers to create a mask to highlight the edges and raise the perceived sharpness of the image.
    Aug 2005
    Hobart, Australia
    1,320
    Craig
    I had bought the Kelby book as a refresher to learn about PS CS, It is a great book. I bought a Bigger book for CS2... And I haven\'t even cracked it.
    I like the Kelby book a lot. It is easy to read and understand.
    T
    Post edited by: tspore, at: 2005/09/18 11:05
  1. Please, I need help with settings?
    By immrshacksaw in forum Site Archive
    Last Post: 12-06-2007, 06:30 PM
  2. L1 + FL-36/FL-50 settings
    By Johnmcl7 in forum Site Archive
    Last Post: 09-20-2007, 11:30 AM
  3. Photo Shop User Magazine Beveled Bubble mask
    By tspore in forum Site Archive
    Last Post: 04-30-2007, 07:23 PM
  4. Replies: 16
    Last Post: 08-17-2006, 09:33 PM
  5. How do you use "Smart Unsharp"?
    By Den in forum Site Archive
    Last Post: 07-17-2006, 03:01 PM
