Re: knocking at the door
That's a great idea!
It basically comes down to the same issue we saw a few days ago with the 18-180 seemingly having a shorter focal length than the 40-150 when focused close up to a subject.
It seems that when focused at short range, the 14-54 has a focal length that is less than 14mm. I'm not sure what it is exactly, but it's less than 14mm. So the trick is to use a negative diopter lens to alter the focusing distance of the lens. It's exactly the opposite of a "close-up filter" (Perhaps, a far-out filter!). This will increase the minimum focusing distance quite a bit, but might allow the lens to be internally focused at 1m (where actual focal length could be 11 or 12mm) to achieve effective infinity focus.
Certainly an interesting way to eke out a few extra mm from a lens!
Luc
Thank you Oly, it's been a good 5-year run!
