The Metz Mecablitz 44 AF4o is a dedicated Olympus system flash which supports the FP TTL mode (called Olympus HSS by Metz).
The olympus version is identical to the other models in looks and use.
Specs:
Guide No at ISO 100/21° (105mm) 44
Guide No at ISO 100/21° (50mm) 34
TTL & FP TTL support
Motor-Zoom, Extended-Zoom
Max angle 24mm
Tilting of head
LCD on the back
Manual mode, EV control (through camera)
Auto-off
cycletimes:
NC batt min: 0.2s, max 4s
Alkaline min 0.2, max 5s
NiMH min 0.2, max 4s
#of (full power) flashes:
NC 600mAh: 85
Alkaline: 240
NiMH 1200mAh: 205
weight: 400g
Pros:
- powerful
- fast
- easy controls
- built quality
cons:
- EV control only through body .. on E1 this means pushing flash button and "+/-" button and dialing main dial. "three fingered salute"
- no turning of head .. for me not an issue, others might disagree
Sample image shot with this flash:
and another one:
both with omnibounce attached to the flash
