Thread: Lumix L1 flash voltage
    London Ontario
    494
    Default Lumix L1 flash voltage
    Got a reply from Panasonic re max flash trigger voltage. It is 20 volts- so my Vivitar 285HV (at 8 volts) is ok!
    Reading, with some trepidation
    987
    Default Re: Lumix L1 flash voltage
    Wow! at 20 volts just about any modern flash unit should be safe. I don't think any of them go over 12 -14 volts.
    Glen Barrington
    Cheese Whiz
    Cool Re: Lumix L1 flash voltage
    Quote Originally Posted by glenbarrington View Post
    I would imagine most modern flashes are under 6 volts, since a lot of Canon's specify 6 volts maximum. However, the ISO standard for flashes specifies that a camera should be able to handle up to 24 volts. The killers were the older Vivitar 285's and 283's that had hundreds of volts.
    987
    Indeed! The most useful thing about my Wein SafeSync is the ability to convert a hot shoe to a standard PC connection!
    Glen Barrington
    Cheese Whiz
    1,652
    just to be completely safe, if you can access a multi-meter
    go here for instructions
    http://www.botzilla.com/photo/g1strobe.html
    "How to Check Trigger Voltage"
    Riley
    Olympus User, Pro Photographer since 2003
    Petach Tikva, Israel
    397
    The problem with some flashes in not a too high trigger voltage, but too low. The FL-36 has a trigger voltage of only 4.4V, and that's why the triac in the eBay radio triggers will not fire (there is a special model where they replaced the triac with a transistor, and that model works fine with FL-36).
    Moshe
  1. E-500/trigger Voltage Question
    By lucian in forum Site Archive
    Last Post: 10-16-2007, 09:21 PM
  2. Old flash with Lumix L1
    By arteacher in forum Site Archive
    Last Post: 07-01-2007, 05:53 AM
  3. Accessories Olympus SHV-01 High Voltage Flash power Pack
    By tspore in forum Member Reviews
    Last Post: 07-30-2006, 04:56 PM
  4. High Voltage Pack
    By KellysCayman in forum Site Archive
    Last Post: 05-24-2006, 08:15 AM
  5. E1 Flash Sync Trigger Voltage
    By iROK in forum Site Archive
    Last Post: 01-20-2006, 01:25 PM
