Thread: Sigma 105mm Macro + EX-25 Advice Reqd.
    62
    Default Sigma 105mm Macro + EX-25 Advice Reqd.
    Hello, I love shooting macro and those of you that do aswell know how addictive it is. I want to get closer, I have the 105mm sigma macro and have taken some fantastic shots with it, BUT i want to go closer for more detail, so i put to you...
    Can i use the EX-25 with the sigma 105mm? is this worth doing? will it benefit me? and what extra will i get in terms of Ratio?
    sorry for the many questions i hope you peeps can help
    Ta Ed
    Default Re: Sigma 105mm Macro + EX-25 Advice Reqd.
    You certainly can use the EX-25 to gain more magnification. How much more, I'm not sure. I believe the Sigma 105 is one of those lenses that lowers its focal length as it focuses closer. If we estimate that it's 70mm fully racked out to 1:1, then perhaps you can go to 1.3:1 or so? Just a guess. If it doesn't drop focal length then the boost will be much less.
    You can also consider adding an EC-14 instead.
    Wisconsin, USA
    1,066
    I'd go with Acme here and recommend a TC instead of a tube for your 105/2.8. In addition to the reason he stated, you also lose working distance with tubes, whereas you gain working distance with a TC.
    More working distance is almost always a good thing... the only time I've ever wanted less working distance was once shooting a 400mm telephoto with a flash... my flash bracket wasn't long enough to throw side lighting on my subject!
    If you want to get REALLY close, you can stack a TC and extension tube... mount it like camera->TC->tube->lens. TCs magnify whatever is in front of them, so putting the tube in front of it gives you more magnification (25mm*1.4=35mm) than putting it behind. I've done this with similar hardware and gotten some great results in the 2x range.
    Chris
    62
    hmmm...interesting replies guys thank you very much. Im interested in getting nearer 2:1, so you reckon a tc-14 would be better than a tube?
    interesting i hadnt thought of that
    thats exactly the kind of help i needed, cheers guys you bunch of legends
    Wisconsin, USA
    1,066
    A 1.4x TC will take your 1:1 macro lens to 1.4:1, so it won't get you quite there. A 2x TC would get you 2:1, but then you lose more image quality and yet another stop aperture... I don't know about you, but a dim viewfinder image is a pain for me when focusing closeups!
    I don't have a Sigma 105/2.8, so I don't know the exact magnification you'll get with tubes. Like acme said, many macro lenses shorten in focal length as you focus closer, which greatly complicates calculating magnification with tubes.
    If a lens were to keep its focal length when focused closer, you could calculate magnification when focused to infinity by using the formula [mag] = 1: ([focal length]/[extension]). So a 50mm lens with a 25mm tube could focus to 1:2 at its furthest.
    I ran the numbers for my Canon 100/2.8 a while back (which shortens to about 60mm at 1:1). These won't be exact for your Sigma, but they should be close... these are minimum and maximum magnification ratios with the given mounted hardware. I have three tubes for my Canon kit (12mm, 20mm, and 36mm) so the "XXmm" numbers are all the tubes added together:
    100/2.8 bare 00mm 0.00-1.00
    100/2.8 bare 12mm 0.11-1.29
    100/2.8 bare 20mm 0.18-1.42
    100/2.8 bare 36mm 0.36-1.69
    100/2.8 bare 32mm 0.32-1.57
    100/2.8 bare 48mm 0.52-1.83
    100/2.8 bare 56mm 0.59-2.0
    100/2.8 bare 68mm 0.71-2.2
    100/2.8 bare 00mm 0.00-1.4
    100/2.8 1.4x 12mm 0.15-1.76
    100/2.8 1.4x 20mm 0.31-1.83
    100/2.8 1.4x 36mm 0.5-2.2
    I stopped calculating at 2x, cause I told myself that if I ever need to go past that I'll buy Canon's 5:1 macro lens. And I haven't yet.
    Also, keep in mind that on Four Thirds, 1:1 means you can fill the frame with an object that's 17.3mm wide. 2:1 gets you down to nearly an 8mm object. That's extremely small! If you don't need to get that small, life is a lot easier below 2x.
    Chris
    62
    that puts it quite nicely thanks a lot
    i think i will start with a cheap set of tubes (as the cheapest option) lock the aperture off with DoF preview and try that. See what results i get. Then i will try TC's, tc's with tubes etc and i may try a 50mm om backwards on the front.
    Thanks chaps
    and yeh agreed i dont need to go above 2:1 lol, i just want to do some really detailed close shots as well as the 1:1 and 1:2 stuff, may have to focus stack tho as focusing is gonna be a nightmare lol especially with a dim viewfinder.....
    Wisconsin, USA
    1,066
    Quote Originally Posted by MrEd View Post
    Thanks chaps
    No problem! Have fun with the tube. Shooting extreme closeups is a lot of fun! Don't be surprised if you burn a ton of money on closeup gear and flash equipment in the next few months...
    Chris
    62
    Quote Originally Posted by ckrueger View Post
    lol! i already done that, been shooting amcro for about a year, got external flas, tripod mount etc etc i just want to get closer but dont wanna just go dumo a ton of money at it yet till i have given extremem close up a try! in case i dont like it....
    i love shooting 1:1 tho
    Other options are close up lenses, or an OM auto bellows ($50-$125) and 80mm f/4 ($125-$300) bellows macro. The 80mm is designed for magnification from 1:2 to 2:1 and produces good results on fourthirds.
  1. Digital Lenses Sigma 105mm Macro lens
    By tspore in forum Member Reviews
    Last Post: 06-29-2009, 10:33 AM
  2. Sigma 105mm f/2.8 EX DG Macro for FT review
    By dpnow in forum Site Archive
    Last Post: 08-09-2007, 04:38 AM
  3. WTB:Sigma 105mm
    By tjbgator1 in forum Buy / Sell Archive
    Last Post: 07-16-2007, 09:59 AM
  4. Replies: 2
    Last Post: 03-28-2007, 02:10 PM
  5. Sigma 105mm f2.8 macro now available
    By E B in forum Site Archive
    Last Post: 10-06-2006, 12:32 PM
