Results 1 to 13 of 13
Thread: Opteka 500mm mirror
    Grindrod, B.C. Canada
    611
    Default Opteka 500mm mirror
    Opteka
    Model - MF 500mm f:8 Mirror Lens
    Groups/Elements: 8/9 <-----mine was 4/5 - 2 mirrors and 3 glass
    Diameter: 3"
    Length: 3.4"
    Weight: 360 grams
    Filter Size Front: 72mm
    Aperture: f:8
    Macro Magnification: 1:2.7
    Minimum Focus Distance: 5.5'
    Manual Focus: Yes
    High quality crystal optics
    Fully Multi-coated
    Made in Japan <----- Mine was made in Korea
    T mount - 4/3s
    PRO
    Cheap
    500mm(1000mm effective)
    Cheap
    very light weight
    Cheap
    very little Chromatic Aboration
    Cheap
    fun
    Cheap
    Very Compact
    CON
    image stabilized or tri-pod a must
    fixed Aperture
    poor contrast
    soft colors
    difficult to focus
    shallow DOF
    poor/strange bokeh
    narrow field of view
    The inexpensive mirror lenses are not for everybody and requires a bit of experience with them to get the results you might hope for. To get results, you must run pictures thru software. The results I have gotten have ranged outright c**p to good. I bought this lens just as an experiment to see for myself if the were as bad as rumored. What I found is that you need a bright sunny day so you can get enough light to over come the f8 aperture and the long lens camera shake. It is very difficult to focus, not only because it is manual, but even with about 270 degrees of rotation on the focal ring, the focus was extremely sensitive. Less than 1 degree of rotation was more than enough to make or break focus. The DOF was very shallow at 10meters DOF is about 6cm. There is little CA as there is not much glass in this lens. A large lens on the front and 2 smaller ones in the rear. A little bit of vignetting is visible There is a large mirror at the rear and a small one at the front. The Bokeh can be distracting and was best if the background was open sky or something without detail. Also I found that although this lens will focus to macro I only got poor images, soft & fuzzy. That said with good light and image stabilized camera I did get some decent $100 lens images. I needed to post process by pushing up the contrast and just a little sharpening. I will take it down to the local duck pond or the bird bath out back and play, I don't think National Geographic will use any of the images but the pictures are decent and I had fun and the lens is cheap cheap.
    Gerry
    611
    Default Re: Opteka 500mm mirror
    Here are 2 images taken at ~3 meters f8, with the Opteka 500mm mirror and a Sigma 50-500mm@500mm. there does seem to be a bit of difference in field of view but it was taken tri-pod mounted. First image is Opteka, second the Sigma. These are out of camera neutral settings and only resized for web. This is about as close as the Sigma 50-500mm can focus so used this as a start point.
    611
    These are at ~10meters same settings. At this distance and greater The Opteka seemed to work better.
    611
    This is the Opteka at macro focus ~2 meters, focus is on the nose
    611
    These are the same images after just a quick bit of post processing, (increase contrast and a light bit of sharpening) they are not that bad.
    796
    Wow,
    im impressed for the cost. Its good to know someone can get 500mm for cheap and thats reasonable...I plan on getting some of these cheap lenses to play with. for general shooting they should be fine.
    E-500
    Zuiko 14-45mm
    Zuiko 40-150mm
    Sony Alpha 350, lots of goodies with it...
    I have gone to the Max!
    Germany
    Jesse
    Quote Originally Posted by ghenton View Post
    Very informative assessment of this lens and thanks for sharing samples and thoughts.
    JW
    Jesse
    Cameras
    Olympus: E-300
    Olympus: EPL7
    Lenses and Stuff
    Olympus: 14-45, 14-54Mk-1, 40-150Mk-1, 35, EX-25, EC-14, HLD-3, ME-1, & RM-CB1
    Fotodiox: Pro 4/3 to m4/3 adapter
    Sigma: 70-200 (m4/3) 19, 30, & 60mm f/2.8 lenses
    Lighting
    Olympus: FL-50
    Altman: 650 watt Fresnel
    Smith-Victor: (2) 720SG focusing floodlights
    FJ Westcott: (2) TD-5 Spiderlites
    Photos
    Ask me
    Sep 2010
    West Sumatra, Indonesia
    257
    Ferry Dwijaya
    Now i know about this mirror lens worked, thanks mate
    Owning a DSLR does not make you a photographer. It makes you a DSLR owner -AnonymousE-3|E-M5|NX-300|Zuiko Digital : 14-54 MK II|ZD 50-200 ED|50/2 IZuiko OM : OM 50/1.4|OM 50/1.8|Tamron : SP 90/f2.5|Tamron 18F|01FMetz 44-AF1|EVF-2|MMF-2|Mal-1NX : 18-55 MK III|SEF-A8Mono-TriPod|Pro Runner 350|Slingshot 200AW|Compuday 150|Toploader 55|Passport Sling
    Aug 2011
    In front of my PC.
    6
    first off, those are optically not very good. Second, youd be using a step-down ring to get a 37mm filter on a 55mm lens, meaning youll have huge vignetting with a little round picture in the center.
    Quote Originally Posted by Garrudae View Post
    Huh? I don't understand what you are referring to in this thread. Who said anything about a filter?
    Apr 2009
    PacNW
    1,809
    Thanks for the review and samples. Not very impressive resolution or contrast. I think I'll save my $100 and put it toward something better.
    February Photos
    March photos
    Comments/criticisms are just my personal opinion and are meant to be constructive. Please feel free to do the same for me.
    Mar 2012
    usa
    Hello,
    Well do you think 500mm is quite good mirror for camera?
    611
    Hi;
    The Mirror lenses are a best value 500mm lens costing from under $100 and up. They have a wide focal range from 3' to infinity. There is little to no chromatic aberration. It is compact and light weight. That said they are difficult to use.
    The 1000mm effective focal length and fixed f8 aperture would be a challenge under the best circumstances using any technology. It is a fixed focal length lens, you need to use your "2 feet" zoom. Image stabilization is a must. The focus is manual and difficult to nail. Mirror lenses by its nature have low contrast, this can be adjusted post camera in software. Bokeh can be distracting (light donuts).
    My conclusions have not changed from the original postings, It is a cheap fun lens to use when I went down to the bird park / duck pond. I have 4 mirror lenses of different makes, all are about the same ( opteka, pentax, zeis and a russian lens) image quality but better build. I take one about once a month out to play with just for giggles. I have about 350 legecy lenses in my collection.
    Gerry
