Results 1 to 19 of 19
Thread: E-510 for Astrophotography
    Mar 2008
    10
    Default E-510 for Astrophotography
    Have an adapter coming to attach my 510 body to the diagonal on my telescope. Has anyone used this camera for lunar, planetary or DSO photography? Any tips for camera settings welcomed.
    Larry
    Default Re: E-510 for Astrophotography
    Quote Originally Posted by woodworker View Post
    Use Live View to gauge how vulnerable your telescope is to vibration, and how long it takes to die down, and set the mirror prefire interval accordingly. Use ISO100 for anything with an exposure over a couple seconds. Stack if you're going to shoot anything longer than a few minutes. Image Stabilization probably won't be useful on any tripod mounted scope.
    More generally, I've yet to find a focal reducer / field flattener for either refractor or catadioptric that was worthwhile. They've introduced more aberrations than any field curvature I've found across the fourthirds sensor.
    Central Texas
    694
    14 (100%)
    You might take a look at Cloudy Nights astronomy forums. There are some folks using Olympus equipment there. A fellow by the name of Clive Owen was using an E-500 with good success last time I visited. Good luck.
    St. Peters, Missouri USA
    1,111
    14 (100%)
    Larry, check out this Yahoo Oly Astro Group site,, much info there and see the 510 all over in discussions,,
    http://tech.groups.yahoo.com/group/O...rophotography/
    Alec who contributes a lot here on Astronomy questions is also a member and contributor there,,
    Derry
    Oct 2008
    Sydney, Australia
    100
    I'm interested also. I have an E-520 on order, and hope to dabble in AP with it. I've not done any AP as yet, but one of my reasons for getting a DSLR was so that I can try hooking it up to my 3 refractors. Sounds like fun :-)
    Sorry I can't give any advice. Good luck with it though, and would be interested to hear how you go!
    Oh, the CN suggestion is a good one. Heaps of knowledgeable people over there. IceInSpace is another good astronomy forum. I'll certainly be trawling the threads there soon myself.
    Mar 2008
    10
    Thanks guys, every little bit helps. The scope is an 11" cat pier mounted in an observatory. I do frequent Cloudy Nights; probably woud be the best place to post but was curious if anyone here was involved. I also have a Philips webcam and have downloaded Astro Capture for image capture and Registax for stacking. I thought it might be easier getting my feet wet with the 510 before advancing to the webcam.
    Larry
    Phoenix Arizona
    1,566
    3DPan and Olyinaz both post here regularly and have shown some amazing shots done with telescopes and Oly equipment. A seach for their posts should bring up some good info.
    112
    The yahoo Oly DSLR astro group is a great resource. Alec posted a set of test images with various E volt cameras in his album there. The 510 does a good job, but I prefer the earlier E500 because its chip has better red response than others.
    I don't post pics here because with dial-up it's too difficult.
    Quote Originally Posted by JohnMinnerath View Post
    This is a good point. Likely not just a CCD vs MOS effect, but also a very strong IR cut filter on everything since the E-330. It doesn't just cut "true" IR, but also deep red. In particular, h-alpha is strongly attenuated, which makes deep space much more tiresome to photograph.
    Mar 2008
    10
    Quote Originally Posted by heavy wind lover View Post
    Derry
    I ran across this site the other day and will be spending time perusing it.
    Larry
    162
    I'll be sure to report your experiences to Roland Christen .
    Quote Originally Posted by archer View Post
    I doubt Roland is using fourthirds sensors, or even sensors with AA filters stuck on them. If he were, and found curvature excessive, I'm sure he could throw sufficient funds into engineering an effective FR/FF, but expect to sign a very large cheque years in advance if you want one for yourself...
    112
    Actually there are good ones and there are not so good ones. And the best will cost you some coin.
    Most critical thing with most I've seen or used is correct position in the light train so they can do their job. Depending on equipment, it can take some digging to find just the right spacers to get everything set up.
    Without doubt the spacing is critical, but I did follow the specs to within a couple mm, as well as a little closer and significantly further out. The Celestron SCT one added coma, and the WO one (different scopes, obviously, and probably two of the most common FR/FFs out there) added coma plus CA. In neither case was field curvature obviously a problem across the fourthirds sensor to begin with, but I was hoping to use more of the image circle. The result was faster, but certainly inferior to the unaugmented scope.
    I have noticed that I prefer the results out of my E1 over the 330 or E3. Have mine mounted on a Celestron C8+, which is, in essence, an 1800mm F10 lens.
    For planets and the moon, I'm finding that I prefer my old Nikkor 400 with 2x teleconverter to the C8. Less distortion.
    Hate to say it, but people using webcams and averaging the noise out over multiple exposures have turned in some pretty astounding results, especially with planets.
    E3, E1, E330, EP1, EM5
    ZD: 7-14, 8FE, PL25 1.4, 14-54, 35-100, 50-200, 70-300 50 Macro, EX-25
    MZD: 12-50, 45 1.8, 14-150
    Nikkor: 105 1.8, 400 3.5, TC301 teleconverter
    FL-50, STF-22
    Quote Originally Posted by TrapperJohn View Post
    Without doubt the humble toucam revolutionized backyard planet shooting. These days I mostly keep telescopes for bright objects and save the SLRs for wide field stuff.
    162
    Roland charges anywhere from $500-$700 for flatteners suitable for a 6x7, in stock. However, he matches them to specific scopes, and THAT will set you back the price of a good used car and a couple years, although with current economic conditions that wait might fall .
    Flatteners have to be matched to the optical system to work well, otherwise they can (and do, as you've learned) introduce significant aberrations.
    Now, for the $1.0e6 question: what scope were you using the WO flattener on, and also, which of the three versions?
    I think I see where your confusion is; you seem to be taking my comment on field flatteners and their use on fourthirds, and expanding it to field flatteners in general. As I understand field curvature, it's usually of parabolic (or roughly thus) form. As the format grows wider, so does its sensitivity to curvature, as it samples the edges of the field. Fourthirds, a relatively small format given the field projected by most backyard scopes, at a minimum, does not gain in quality when combined with a field flattener / focal reducer in my experience.
    Celestron .63x converter on a Celestron 200mm f/10 SCT, and WO WE-FLAT-2 .8x on a WO ZS 80mm FD. Both have been tried on other scopes as well, but if they don't make gains there I don't know where they would.
    Aug 2008
    NJ
    184
    I just sold my FFIII WO flattener/reducer which some people have had better results from than the Flat 2. I didn't get a chance to use it before having to sell off some equipment so cannot comment from personal use.
    I tried using my E420 to do some 30 secoond subs at ISO1600 but found it very noisy; haven't had a chance to experiment since that night.
