Thread: Help - diaphragm Jammed on 12-60 lens
    Aug 2007
    17
    Default Help - diaphragm Jammed on 12-60 lens
    Out shooting the other day, while I was looking through the viewfinder the diaphragm on my 12-60 (on an E520) shut all the way down, and won't open.
    I've upgraded the body software, tried the lens on other bodies, no joy.
    Any ideas??? Please?
    The Hague, The Netherlands
    1,040
    Default Re: Help - diaphragm Jammed on 12-60 lens
    Other then hitting the lens to try and shake the blades loose, not really.
    Sounds like a repair job.
    Have you tried dialing in f/2.8 or anything else besides fully closed, and hitting the Fn (DOF preview) ? Perhaps that will shake it loose. But even if it does come loose, big chance it'll happen again.
    E-30/E-PL1/OM-D E-M5/E-M1
    ** Micro 14-42mm ** Micro 45mm f/1.8 ** Micro 17mm f/1.8 **
    ** 40-150mm II ** 9-18mm ** 12-50mm **
    ** ZD 150mm f/2 ** 12-60mm SWD ** 50-200mm SWD **
    ** Sigma 30mm f/1.4 ** EC-20 ** Two FL-36R **
    ** Samyang 85mm f/1.4 ** OM 50mm f/1.8 + f/1.4 **
    ** Leica Elmarit 180mm f/2.8 ** Vivitar 35-70mm f.2.8-3.5 **
    http://www.flickr.com/photos/thx1138sgl/
    Aug 2007
    17
    As I watched it stop down, it's not mechanical - although that didn't stop me trying to shake it a couple of times. And yes, have tried all manner of shooting options (changing it in "A" mode, etc etc).
    Ham
    1,040
    Did you clean the electric contacts on the lens mount ?
    Aug 2007
    17
    Quote Originally Posted by thx1138 View Post
    Yes. And tried shorting the contacts on the lens (not the body). And tried moving the setting on and off "Reset Lens"
    1,040
    If it's still under warranty, Oly will fix it for sure. Doesn't seem like you used it the wrong way so it must be a manufacture fault.
    Hope things work out ok.
    Aug 2007
    17
    Yes, thanks, I realise that. As much as anything I'm hoping (!!) someone else has had the same experience and it is something that can be fixed in the field.
    I'm planning what to take on a trip to China. As I need to travel light I was contemplating just a 520 with the 12-60, now I need to re-think that.
    Ham
