Universal 1.3x Viewfinder Magnifier
After hearing mixed feelings over the ME-1 eyepiece, and having a good experience with previous generic off shore accessories, I decided to give this a go. For $29 USD shipped, within two weeks I received this 1.3x eyepiece magnifier from Hong Kong. Ordered from a seller on ebay and arrived just as described. Based on looks, it appears more promising than the ME-1. I attached it to my E-510 and had a "before an after" look. To my disappointment I did not see any improvement in viewfinder size or magnification. I spent a few minutes examining how this all works. When attached, the unit sticks out about 2cm from the camera. If you hold your camera about 2cm from your eyes and look through the regular viewfinder, then slide the magnification lens in between, you would see that the lens does actually magnify 1.3x. The disappointment is that bringing the camera closer to your eye, without the magnifier, does the same thing. So in comparison of your camera with or without the magnifier, the image is about the same size, and the magnifier only decreases quality and adds to the "tunneling" affect that I was hoping wouldn't happen. I was going to include a picture comparison in this review, but it's just not worth it.
There is only one situation in which this device would help someone. IF you normally hold your camera about 2-3cm from your eye to avoid your nose bumping the LCD, then this adapter will actually increase your perceived viewfinder size. However, IF you normally hold your camera with the viewfinder pressed to your eye, this attachment will offer no apparent magnification. The magnification it gives will be lost by the increased distance that it pushes the camera away from your eye.
I tested with and without eyeglasses, same result.
This sums it up. I just wasted $29 worth of beer money.
-Mark
E-PL2 | WCON-07 | 14mm F2.5 | 20mm F1.7 | Pentax 25mm F1.4 | 35mm F1.7 c-mount | FL-50 | MA1 | SEMA-1
OM-2n | 28mm F3.5 | 50mm F1.4 | 135mm F3.5 | Sigma 600mm F8 | T-20 | 2x Vivitar 2800
