Thread: Accessory bag for easy lens changes?
    Jul 2011
    12
    Default Accessory bag for easy lens changes?
    I have a Lowepro nature trekker backpack that I use to carry all of my equipment. The problem I have is changing lenses with any speed at all. Taking the bag off, opening it, and changing lenses can be quite a chore. I am looking for something that can be worn around my waist or over my shoulder that will hold 2 lenses (a third will be on my E-5). I bought a Lowepro AW200 lens exchange bag which works really well but only holds one lens. I normally shoot with a 12-60, a 50-200, and a Sigma 105mm macro. Any help in finding the perfect solution is very much appreciated!
    Mar 2011
    Tucson, Arizona - Eugene, Oregon
    340
    Default Re: Accessory bag for easy lens changes?
    I got the Lowepro 'Slingshot' which has only one strap, so you can pivot it around for access.
    E-510 IR 665nm, 14-42mm II, 40-150mm II
    OM-D E-M1 +
    14-54mm II
    Body Cap Lens 15mm f/8 & 9mm f/8 "fisheye"
    Mar 2010
    Kununurra, Aus
    189
    Thinktank belt, holster for camera with two lens bags. I have hiked for 10 hours up a mountain with this setup. Only problem is that they need to put a leg strap to hold the holster in place. Having said that, my holster is capable of holding the 35-100 on the E5 with the lens hood in position. So if you had a smaller one the leg strap issue might not be an issue.
    McGoo Photography
    E5 | E620 | Zuiko 7-14 | Zuiko 14-54 | Zuiko 35-100 | Zuiko 70-300 | FL-50R x2 |
    I use a small shoulderbag - the Tamrac Express 7.
    West central Illinois (USA)
    892
    Tamrac Velocity 8X sling bag is what I use. Fairly "configurable" -- 9-18 and 50 stack down one side (separated by detachable padding), 50-200 down the other (a little snug with tripod collar on, but manageable), center holds E-5 with 12-60 attached (or some combination of another lens, FL-50, rocket blower). Swing the bag around to your side or front, zip top opens away from you for quick access to main compartment, makes kind of a little "changing station." Zip compartment on inside of zip top, large accessory compartment on front of bag. (No, I don't work for Tamrac -- just like this bag.)
    Old enough to know better, young enough not to care.
    E-5, E-3, E-500; ZD 9-18, 12-60, 14-54 I, 35, 50, 50-200 SWD, PL 25; EC-14; FL-50, HLD-4
    E-M5; m.ZD 12-50, MMF-3, HLD-6
    Nikon D800,
    Nikkor 14-24mm f/2.8G ED, 24-70mm f/2.8G ED, 70-200mm f/2.8G ED VR II, 80-400mm f/4.5-5.6G ED VR II, 105mm f/2.8G ED IF VR micro
    B+W & Cokin filters, Giottos MT-8361 tripod with Acratech GP ball head
    jlhemingwayphotos.com
    Jul 2011
    12
    Has anyone used the Thinktank lens changer 2 or 3? One of those look like what I'm looking for.
    Van Nuys, CA
    663
    The best way to change lenses in the field is not to have to. Get at least one other body, and come up with a way to carry both comfortably. (If you have aspirations of working for money, you will need at least one backup body anyway, in case something dies or is damaged during a job.)
    When I'm working, I generally have my 35-100mm or 50-200mm on my E-3 w/grip at my left hip, hanging from a Lens Loop strap attached to the lens' tripod foot. It usually has my FL-50 on it (with external battery pack on my left shoulder if I'm shooting a wedding). I have my 12-60mm on my E-520, which is on a nice neoprene strap on my right shoulder, turned so it hangs with the lens facing in. The E-520 usually has my Metz 48 flash on it. Both bodies have lens hoods in-place, to avoid lens damage. I keep a 4-pack plastic holder of charged Eneloop AA cells in my pocket, along with a spare BLM-1. I have extra memory cards in a holder on the E-520 strap.
    I can easily grab either camera quickly & shoot. I have them both pre-set in manual mode for the current lighting conditions and my shooting preferences -- outdoors, this is often ISO 200, f/4.0 or so, and around 1/800s shutter speed, sunny WB, center zone metering, and IS off. Focus spots are set based on what I'm shooting. I'll let a camera meter off a green lawn or the open palm of my hand to sanity-check my manual exposure settings; it's not always exactly right, but based on experience, I know how many stops to adjust *my* cameras to make it right in each case (my hand: +0.7 EV for the E-3, +0.3 EV for my E-520; vibrant green grass: no adjustment to the E-3, -0.3 EV for the E-520; dead grass or dry lake bed dirt: +0.3 EV for the E-3, no adjustment for the E-520).
    I carry a number of other lenses for "specialty shots" (such as my 9-18mm, 50mm macro, or 70-300mm), but I generally have plenty of time to go grab them out of my small Tamrac backpack or my big gear cases if I need them. I also keep my E-1 handy in one of the bags, usually with my 14-54mm on it, just in case I have an equipment failure with one of my main bodies.
    I also have small camera case with an E-PL1 w/ 14-42mm on it, and my old 40-150mm lens on a 4/3 adapter. My FL-36R is in that case, too, along with a charged 4-pack of Eneloop AA cells and a couple of spare BLS-1 batteries. The E-PL1 kit is my "always on-hand" kit. It lives in my vehicle, and only comes out to use it. I am NEVER without a pro-quality camera on-hand, just in case.
    Cameras: Yes.
    Lenses: Yes.
    Lighting: Sometimes, depending upon needs.
    Misc.: Other stuff, as needed.
    CrayonPhotos.com ... pictures that draw you in.
    Follow me on Twitter.
    Like me on Facebook.
