Thread: Hot shoe adapter for Olympus Pen
    146
    Default Hot shoe adapter for Olympus Pen
    Since my E-PL3's hot shoe seems to be bad I am wondering if there is an adapter that I can clip into the accessory port? Or perhaps is there a more advanced flash that clips into the accessory port than the one that comes with the camera?
    John Cowan
    Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut.
    ~Ernest Hemingway~
    107
    Default Re: Hot shoe adapter for Olympus Pen
    Another option might be to use the clip-on flash to trigger one of the R flashes, FL-300R, FL-36R, or FL-50R.
    146
    Quote Originally Posted by bob View Post
    That is certainly an option, but it doesn't really work for my style. I do not shoot in studio, or use fancy dancy lighting schemes. I use my flash for candid stuff, and just when I need good light walking around. Not having it attached to my camera is kind of a problem for me. I am wondering if the camera can trigger the flash remotely on its own? If so I could just tape the contacts and use it like a remote flash, but in the shoe.
    John Cowan
    ~Ernest Hemingway~
    146
    I can't even figure out how to get the clip light to trigger the remote flash. And I am not seeing it in the manual anywhere for either unit.
    John Cowan
    ~Ernest Hemingway~
    Quote Originally Posted by almo View Post
    Page 93 of the E-PL3 manual covers wireless flashes, assuming you have a R-flash (FL-300R, FL-36R, FL-600R, FL-50R from Olympus, or mid to high end Metz flashes). IIRC, you had a FL-36, not a FL-36R.
    If you are willing to use the flashes in manual mode (or the 1970 era 'auto' mode), you can get a slave trigger that sees the pulse of the clip-on flash and fires the flash. You typically would need to shoot in manual flash mode (as well as manual camera mode) with the power level dialed down.
    You don't have to have the flash mounted on a light stand, you could mount it on a bracket along with the camera. If you are in a small room, the slave trigger will see reflections from the flash from the back wall. If you are in a larger room or outdoors, you would need to make a light pipe, either with some aluminum foil over the pop-up flash, and ending over the sensor for the slave trigger. You could also use a fiber optic cable or a light pipe tube like: https://www.sparkfun.com/products/10697
    If you are handy with tools it is fairly simple to make a bracket. If not, you could get a simple straight bracket: General Brand Straight Flash Bracket VA322 B&H Photo Video or a right angle bracket: General Brand Right Angle Bracket with 2 Flash Shoes VA320 B&H.
    146
    I have the FL-36. No remote for me. Damn.
    John Cowan
    ~Ernest Hemingway~
