Results 1 to 15 of 15
Thread: Indoor shots with flash fails miserably
    Lappeenranta, Finland
    53
    Question Indoor shots with flash fails miserably
    Hi
    Just asking here before running through the whole camera manual.
    When taking pictures inside with flash the images taken are too
    underexposured no matter how I set the ISO or aperature ..
    yes .. there might be some deviation when doing that but
    seems like there is some setting wrong (or my e-30 broken down..).
    The pictures I get are all too dark and have lots of noise - they are of
    no use.
    any suggestions.. ? .. never happened to me with my long gone e-300 . . .
    br.
    smogu
    smogu (e-300),14-45,14-54 mk1,40-150,ex-25,ec-20,70-300
    53
    Default Re: Indoor shots with flash fails miserably
    for example this .. how can it be so dark .. hope the exif information is still there ..
    ISO-400, flash used, flash mode flash, compulsory, exposure 1/60, f f/3.5, . . i hope this is
    some stupid user error ..
    Could be many causes. I assume this is the pop-up flash and not a hotshoe flash? You can tell it fired and is synching correctly with the shutter, from the shadow and jacket reflection.
    I'd first check the flash exposure setting to make sure it's set to neutral or even introduce over-exposure. Try a higher ISO setting and different meter patterns. Oly Viewer is helpful because it displays pretty much all the camera settings; more than a typical EXIF viewer.
    It's probably something simple.
    Good luck,
    If you are using Aperture priority, that might be the reason. I know that my Canon 60d has special options governing how the flash will behave in Aperture mode. I guess it is because A mode by definition makes the camera set the shutter speed, but using the flash also makes it chose a shutter speed for a proper synch speed. So there can be a conflict. Or something like that. I find flash very confusing anyway. I do know that I usually switch to Program mode (oh, the shame!) when using the flash because it's easier than dealing with all that.
    Not sure if this is your problem, of course...
    Sep 2014
    27
    The EXIF is there...
    Camera Maker: OLYMPUS IMAGING CORP.
    Camera Model: E-30
    Image Date: 2014-12-21 11:14:59 (no TZ)
    Focal Length: 27mm
    Aperture: ƒ/3.5
    Exposure Time: 0.017 s (1/60)
    ISO equiv: 400
    Exposure Bias: none
    Metering Mode: Spot
    Exposure: aperture priority (semi-auto)
    White Balance: Auto
    Flash Fired: Yes (Auto, return light detected)
    Color Space: sRGB
    I have vague memories of many discussions about this back in the 4/3 days. You're using aperture priority which forces the flash to function as a fill-flash and I believe that especially when combined with spot metering, there are some strange results. If you shoot in P or S, I believe the problem goes away as it uses to flash to expose the scene properly rather than just powering it enough to be a fill. If it doesn't, then I'd be curious what your results are with evaluative metering.
    I recall there was this thread in 2008, where travelfotographer weighed in on how Olympus choses the flash settings: http://forum.fourthirdsphoto.com/thr...d-P-with-flash.
    Unfortunately travelfotographer is not listed as a current member.
    Quote Originally Posted by snap View Post
    Yes, that's exactly what I was talking about in my post above. I remembered after I shut down my computer that the default flash on my 60D in Aperture mode was FILL-FLASH, not regular flash, because of what you said. So when you tried to use it, you got a very poorly lit scene. The options the camera has allow you to change this behavior (like use the flash fully even in A and use a proper synch speed).
    Now that I see the exif, I am almost positive that this is the problem here.
    @RAH: Canon works very differently to other makers when it comes to flash in Aperture mode. So I think there is something else going on here. 1/60s, f/3.5 and ISO 400 should render this scene sensibly. What is the flash exposure compensation set to? I can't find that info in the EXIF.
    Yes, you could be right, and I agree that the flash should work fine under the exif options shown.
    I checked my notes from earlier and the default for a Canon camera using the built-in flash in Aperture mode is to give you an exposure as though you are not even using a flash, with the flash only firing as a fill-flash. In other words, in low-light conditions, you will get a very slow shutter speed and you'd better be on a tripod. But you will not get the dark conditions shown in the sample.
    One of the options Canon has is "#2 - 1/250", which gives you a shutter speed of 1/250 regardless of the available light, and then uses the full flash to light the scene. So is that just what Olympus defaults to, something like that? If so, then yeah, looks like the OP has a different problem.
    Now I remember why I get confused about flash...
    Sep 2010
    Tampa, Florida
    539
    25
    Just another thought. I don't have an E-30, but on my E-3 I have several options for flash control, from full all the way down to 1/64 power. Check you E-30 for your flash control options. That is totally different from your exposure control, and similar to the comments above about Canon's "Fill Flash"
    Steven R
    Tampa, Florida
    E-330, E-520, E-3
    Recent Olympus cameras have an option to separate exposure adjustment from flash adjustment. If you don't enable the menu, you won't see the menu to adjust the power of the flash.
    One other thought would be if you are doing a remote flash setup using an optical trigger, you need to set the trigger flash to manual power mode (typically setting 1/64 or 1/128 power, whichever your camera has). If you use a normal flash mode, Olympus will fire a pre-flash to figure out settings, and the remote flash then would fire when it sees the pre-flash, and it would be charging when the main flash is fired, leaving the scene dark. It didn't sound like you were doing remote flash, but I thought I would mention it.
    53
    hi..
    thx for the possible causes of this ..
    checking it out as soon as possible ..
    i first thought that it was the polarizing filter I had on
    but the removal did not help a thing ..
    Dug out my E-30 to refresh my memory. The SCP has two flash menu items:
    -Lightning bolt gives access to auto, redeye, off, 2nd curtain, full and fraction settings to 1/64.
    -Compensation mode (below) gives -3 to +3 EV range.
    My bet is your solution is in one of these menus.
    ETA Wow, I haven't shot the E-30 since January '14. Battery was flat but luckily it hadn't reset everything.
    Erie PA
    339
    Also check the contacts on E30; I had one stop communicating with the camera/lens also make sure you don't have the E30 onboard flash in radio control. That has happen to me on several occasions when I forget to reset as I am scratching my head why the Flash is not syncing and getting dark images.
    Lou Cioccio
    Diamond, Missouri
    1,209
    43
    why would you be using spot metering for an indoor flash shot?
    FLICKR
    Have a great day!
    Lorey
    Please ask before editing images. Thank you.
